[postgis-devel] --with-libfoo
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Mon Aug 4 06:24:55 PDT 2014
On 04/08/14 09:01, Sandro Santilli wrote:
> On Fri, Aug 01, 2014 at 02:29:27PM -0700, Paul Ramsey wrote:
>> Hey devs,
>> I had to do a build for Solaris recently, and ended up having to patch configure.ac to do it, because of the way we reference external libraries.
>> Basically, we assume that any external library will be installed in /some/prefix/lib and /some/prefix/include. So we only expect to need /some/prefix in our configuration in order to find the necessary parts.
>> In solaris 64 bit, the includes are are in /some/prefix/include but the libraries are in /home/prefix/lib/64.
>> I noted that cmake has this general idea baked into their patterns for extension libraries, the expectation that include and lib paths be declared independently.
>> In the end, I changed
>> —with-projdir
>> to
>> —with-proj-includedir
>> and
>> —with-proj-libdir
>> I’d like to do a similar thing to trunk. I could try and keep the old syntax around, or just remove it in favor of the split syntax.
>> Thoughts?
> Please try to keep the old syntax around too, shouldn't be hard
> (just have the --with-xxxdir processed first)
> If you're up for some fun, having a PGIS_FIND_PACKAGE m4 macro
> might help making these things easier to maintain.
Yeah. I'm interested to how someone managed to build PROJ.4 in this way,
as it goes beyond a simple --prefix into configure. Before jumping in,
do we know the configure options that were passed to PROJ.4 when it was
built in this way?
Plus I agree with Sandro; if this is a common problem on platforms such
as Solaris then maybe there is already an existing macro we can use to
resolve the issue?
ATB,
Mark.
