[postgis-devel] Building on FreeBSD
Greg Troxel gdt at ir.bbn.com
Fri Aug 22 16:04:35 PDT 2014
Robert Kruus <rob.kruus at gmail.com> writes:
> The fix in ticket http://trac.osgeo.org/postgis/ticket/2620 breaks
> compiling on my FreeBSD box (for 2.1 obviously and most likely from there
> forward).
> Probably want to add another || in there:
> #if defined(__FreeBSD__) || defined(__FreeBSD_kernel__) ||
> defined(__OpenBSD__)
> Also see
> https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=192840#c30
I am having trouble following this.    It seems suboptimal to be
checking for a define that asserts a kernel implementation.   Does
kFreeBSD install header files in /usr/include/sys that match the kernel
interfaces?  Why isn't there instead a feature test from kernel headers,
rather than a specific name?
It seems particularly dodgy to define LINUX on systems that aren't
linux, or for things to be ifdef'd on LINUX, rather than aiming for
POSIX.  But I have no historical context for this entire situation, so I
could well be missing something.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140822/cb98fd10/attachment.sig>
