[postgis-devel] address standardizer extension
Paragon Corporation lr at pcorp.us
Wed Aug 27 02:41:27 PDT 2014
I haven't incorporated changes into configure.ac yet.  Just the logic to
generate the make files.  My plan is to build it as part of the make install
script if all the prequisites are present.
-----Original Message-----
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
Sent: Wednesday, August 27, 2014 5:18 AM
To: postgis-devel at lists.osgeo.org
Subject: [postgis-devel] address standardizer extension
Is it normal for the address standardizer extension to not be built
automatically on "make" ? I ask because it is found under the extension/
dir. If it's not to be integrated it should reside in the extra/ dir
instead.
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
postgis-devel mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
