[postgis-devel] address standardizer extension
Sandro Santilli strk at keybit.net
Wed Aug 27 03:11:47 PDT 2014
On Wed, Aug 27, 2014 at 05:41:27AM -0400, Paragon Corporation wrote:
> I haven't incorporated changes into configure.ac yet.  Just the logic to
> generate the make files.  My plan is to build it as part of the make install
> script if all the prequisites are present.
Ok. Please build it as part of "make" though, and only install it as
part of "make install" :)
The extensions/Makefile.in file should be changed to optionally add
address_standardizer to SUBDIRS.
Btw, looking at it, postgis_tiger_geocoder is also missing.
Should it have the same threatment ?
--strk;
> -----Original Message-----
> From: postgis-devel-bounces at lists.osgeo.org
> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
> Sent: Wednesday, August 27, 2014 5:18 AM
> To: postgis-devel at lists.osgeo.org
> Subject: [postgis-devel] address standardizer extension
> Is it normal for the address standardizer extension to not be built
> automatically on "make" ? I ask because it is found under the extension/
> dir. If it's not to be integrated it should reside in the extra/ dir
> instead.
> --strk;
>  ()  ASCII ribbon campaign  --  Keep it simple !
>  /\  http://strk.keybit.net/rants/ascii_mails.txt
> postgis-devel mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
