[postgis-devel] address standardizer extension
Sandro Santilli strk at keybit.net
Wed Aug 27 03:42:06 PDT 2014
On Wed, Aug 27, 2014 at 06:17:34AM -0400, Paragon Corporation wrote:
> It doesn't?  It automatallically gets built as far as make ? I thought it
> did as part of make install as well.  Have to double check my scripts (I may
> just read from the extensions folder instead of postgres folder so could be
> mistaken on the make install part)
Ah, you're right, I misread it.
The tiger geocoder gets into SUBDIR unconditionally, so this is back
an "address standardizer" only issue :)
--strk;
