[postgis-devel] Hello!
Paul Ramsey
pramsey at cleverelephant.ca
Sat Feb 8 10:23:36 PST 2014
you can collaborate between each other however you wish.
Just confirm that patches apply cleanly to svn before attaching to a ticket,
P.
http://postgis.net
http://cleverelephant.ca
On February 8, 2014 at 4:38:30 AM, Baris Ergun (barisergun75 at gmail.com) wrote:
> Hi Paul;
> Is it ok if we share our patches with git diff from git mirror or
> u suggest
> svn diff? svn ignore is more boring compared to git ignore
> On 30 January 2014 23:17, Baris Ergun
> wrote:
> > Hi Enrico;
> > I have also plans of adding Extended (EWKB) geometry type support
> to
> > Postgis. But before I would like to concentrate on tidying up
> the pom.xml
> > for jdbc and jts parser. And + aiming to make the next releases
> available
> > on Central Maven repository. If you have noticed 1.3.3 is the
> latest on
> > rep. Just keep in touch. We can make a plan on how we can coordinate
> our
> > efforts together.
> > Best.
> > On 30 January 2014 21:19, Paul Ramsey
> wrote:
> >> Enrico,
> >> You should coordinate any jdbc work with Baris, who is also
> doing some
> >> work in the java area. I don’t think he’s started on any of the
> big changes
> >> (curves, etc) but you should make sure you don’t overlap
> >> P
> >> Paul Ramsey
> >> http://postgis.net
> >> On January 30, 2014 at 3:27:54 AM, Enrico Rampazzo (iarendis at gmail.com)
> >> wrote:
> >> Hello all,
> >> I am Enrico Rampazzo, I just subscribed to this mailing list
> and I
> >> thought to say hi to all of you.
> >> I am mainly a java developer, my knowledge of C is pretty basic,
> and I
> >> would like to help improving the postgis-jdbc support for
> the geography
> >> data type. I have seen that the BinaryWriter/BinaryParser
> classes already
> >> allows to encode/decode geometries as well as geographies,
> but I would like
> >> to register a JDBC type for Geography and and in general, allow
> the
> >> manipulation of geography columns from ORMs such as Hibernate.
> >> Is there someone who is already working on this?
> >> Best regards,
> >> Enrico
> >> _______________________________________________
> >> postgis-devel mailing list
> >> postgis-devel at lists.osgeo.org
> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> > Barış
> > www.linkedin.com/in/barisergun
> Barış
