[postgis-devel] Java Maintenance
Bborie Park dustymugs at gmail.com
Tue Feb 25 12:26:21 PST 2014
+1. Bit-rot bad...
-bborie
On Tue, Feb 25, 2014 at 12:25 PM, Paul Ramsey <pramsey at cleverelephant.ca>wrote:
> Hi Devs,
> We have the potential for active maintenance of the Java chunk of the
> distribution, and I would like to give Baris Ergun commit privs to the java
> sub-tree. He’s already provided a couple of patches that look fine, and
> most importantly is thinking about the implications of his changes in the
> large before applying.
> Please give me a vote on that (the alternative is continuing Java branch
> bitrot)
> P
> Paul Ramsey
> http://cleverelephant.ca
> http://postgis.net
> On February 25, 2014 at 10:51:52 AM, Baris Ergun (barisergun75 at gmail.com<//barisergun75 at gmail.com>)
> wrote:
> Hi Paul;
> Did u have a chance to check the issue
> Thanks.
> On 20 February 2014 22:15, Baris Ergun <barisergun75 at gmail.com> wrote:
>> I have updated the issue with Alternative approaches. Your version number
>> concern still floating. According to preferred approach we can continue to
>> discuss.
>> On 16 February 2014 02:42, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>>>  Please see my ticket comment. I’m worried about having a version
>>> number flapping along in there.
>>>  P.
>>> Paul Ramsey
>>> http://postgis.net
>>> On February 15, 2014 at 10:57:18 AM, Baris Ergun (barisergun75 at gmail.com<//barisergun75 at gmail.com>)
>>> wrote:
>>>    Hi Paul;
>>> I have generated a git patch for the git mirror of svn-trunk. It
>>> basically removes unnnecessary lines in pom.xml and prepared against
>>> sonatype guide. If you can review and apply this patch and the next coming
>>> related patches quickly It would help my communication with Sonatype guys.
>>> Basically the mvn clean install still works for everyone checking out the
>>> codes. The changes will be affecting only publishing to Central rep so I
>>> hope it wont break anyones build etc.. And also publishing to Central rep
>>> is not active at the moment so it wont break anything on that path since it
>>> is already broken.
>>> I have already opened a Sonatype Jira ticket for publishing of
>>> postgis-jdbc jars to Sonatype Central repository.
>>> Thanks.
>> Barış
>> www.linkedin.com/in/barisergun
> Barış
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140225/89c7774f/attachment.html>
