[postgis-devel] Java Maintenance
maplabs at light42.com maplabs at light42.com
Tue Feb 25 15:15:51 PST 2014
the following projects are running very well with OpenJDK 7 on Ubuntu
12.04 base:
* 52nSOS, 52nWPS, 52nWSS
* deegree
* geomajas
* geonetwork
* geoserver
* ncWMS
* uDig
  (doing my part to combat OpenJDK f-u-d)
Brian M Hamlin
OSGeo California Chapter
blog.light42.com
On Tue, 25 Feb 2014 23:05:00 +0100, Nicklas Avén  wrote:
       This sounds great to me.
I don't know enough about Java but do we have any thoughts about that
the code shall work with the open Java alternatives?
In many Linux distributions Oracle Java is a pain to keep updated with
manual updating. Especially since they release a new security release
about once a week.
/Nicklas
Skickat från min Samsung Mobil
-------- Originalmeddelande --------
Från: Paul Ramsey
Datum: 25-02-2014  21:25  (GMT+01:00)
Till: PostGIS Development Discussion
Kopia: Baris Ergun
Rubrik: [postgis-devel] Java Maintenance
Hi Devs,
We have the potential for active maintenance of the Java chunk of the
distribution, and I would like to give Baris Ergun commit privs to the
java sub-tree. He’s already provided a couple of patches that look
fine, and most importantly is thinking about the implications of his
changes in the large before applying.
Please give me a vote on that (the alternative is continuing Java
branch bitrot)
P
Paul Ramsey
http://cleverelephant.cahttp://postgis.net
On February 25, 2014 at 10:51:52 AM, Baris Ergun
(barisergun75 at gmail.com) wrote:
       Hi Paul;
  Did u have a chance to check the issue
  Thanks.
On 20 February 2014 22:15, Baris Ergun  wrote:
        I have updated the issue with Alternative approaches. Your
version number concern still floating. According to preferred approach
we can continue to discuss.
On 16 February 2014 02:42, Paul Ramsey
  wrote:
          Please see my ticket comment. I’m worried about having a
version number flapping along in there.
   P.
Paul Ramsey
http://cleverelephant.ca http://postgis.net
On February 15, 2014 at 10:57:18 AM, Baris Ergun
             Hi Paul;
  I have generated a git patch for the git mirror of svn-trunk. It
basically removes unnnecessary lines in pom.xml and prepared against
sonatype guide. If you can review and apply this patch and the next
coming related patches quickly It would help my communication with
Sonatype guys. Basically the mvn clean install still works for everyone
checking out the codes. The changes will be affecting only publishing
to Central rep so I hope it wont break anyones build etc.. And also
publishing to Central rep is not active at the moment so it wont break
anything on that path since it is already broken.
  I have already opened a Sonatype Jira ticket for publishing of
postgis-jdbc jars to Sonatype Central repository.
  Thanks.
  Barış www.linkedin.com/in/barisergun
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140225/3d30f1a1/attachment.html>
