[postgis-devel] Travis Failing with Weird Error on My MapAlgebra Mask Pull Request
Bborie Park dustymugs at gmail.com
Fri Jan 3 10:27:30 PST 2014
I'll test this tonight. I just haven't had much time lately.
-bborie
On Fri, Jan 3, 2014 at 10:18 AM, Nathaniel Hunter Clay <
clay.nathaniel at gmail.com> wrote:
>  Hi everyone,
> Travis is failing on my pull request, however I am able to get a clean
> build on 9.3 and 9.1, make test that runs both the SQL and cunit test with
> out a problem. However Travis is failing with the following error:
> $ cat /tmp/pgis_reg/*
> createlang: language "plpgsql" is already installed in database
> "postgis_reg"
> SET
> BEGIN
> DO
> CREATE FUNCTION
> psql:/home/travis/build/postgis/postgis/regress/00-regress-install/share/contrib/postgis/postgis.sql:86:
> ERROR: could not load library
> "/home/travis/build/postgis/postgis/regress/00-regress-install/lib/
> postgis-2.2.so":
> postgis-2.2.so: undefined symbol: palloc0
> I am stuck, any help would be appreciated.
> Many Thanks,
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140103/7214cf6d/attachment.html>
