[postgis-devel] Travis Failing with Weird Error on My MapAlgebra Mask Pull Request
Nathaniel Hunter Clay clay.nathaniel at gmail.com
Fri Jan 3 10:35:40 PST 2014
Thank you Dustymugs
On 1/3/2014 1:27 PM, Bborie Park wrote:
> I'll test this tonight. I just haven't had much time lately.
> -bborie
> On Fri, Jan 3, 2014 at 10:18 AM, Nathaniel Hunter Clay
> <clay.nathaniel at gmail.com <mailto:clay.nathaniel at gmail.com>> wrote:
>     Hi everyone,
>     Travis is failing on my pull request, however I am able to get a
>     clean build on 9.3 and 9.1, make test that runs both the SQL and
>     cunit test with out a problem. However Travis is failing with the
>     following error:
>     $ cat /tmp/pgis_reg/*
>     createlang: language "plpgsql" is already installed in database
>     "postgis_reg"
>     SET
>     BEGIN
>     DO
>     CREATE FUNCTION
>     psql:/home/travis/build/postgis/postgis/regress/00-regress-install/share/contrib/postgis/postgis.sql:86:
>     ERROR: could not load library
>     "/home/travis/build/postgis/postgis/regress/00-regress-install/lib/postgis-2.2.so
>     <http://postgis-2.2.so>":
>     <http://postgis-2.2.so>: undefined symbol: palloc0
>     I am stuck, any help would be appreciated.
>     Many Thanks,
>     _______________________________________________
>     postgis-devel mailing list
>     postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140103/6306f36a/attachment.html>
