[postgis-devel] Postgis topology creation - O(n-squared)? - creates problems with large datasets.
Stephen Woodbridge woodbri at swoodbridge.com
Fri Jan 10 13:04:06 PST 2014
On 1/10/2014 3:40 PM, Graeme B. Bell wrote:
> OK, I'm assuming that since this is a database list the word transaction carries a certain formal weight.
>   e.g.
> "In PostgreSQL, a transaction is set up by surrounding the SQL commands of the transaction with BEGIN and COMMIT commands."
> http://www.postgresql.org/docs/8.3/static/tutorial-transactions.html
> I agree that normal postgres commands carry much of the function of a transaction.
Hi Graeme,
Yes, in postgresql a "transaction" is a collection of statements that
get executed and the results either get committed for all of the
collection or non of it in the case of an error or explicit ROLLBACK.
This is a feature that allow you to keep the database in a know clean
state. There are also some side effects of this, like the fact that
other processes can not see the intermediate result of a tranasaction in
process until it has been committed so they don't get weird intermediate
or incomplete results when running a query.
It is a little less obvious that all the work done in a function call is
also done in the context of a transaction. So when you call a function
like say ST_CreateTopoGeo(...) that this is implicitly run inside a
transaction.
Transactions in general have some impact on performance and memory usage
to support this behavior.
-Steve
