[postgis-devel] multisurface definition in bnf-wkt.txt
Mateusz Łoskot mateusz at loskot.net
Mon Jan 13 03:20:05 PST 2014
I see.
The *messy* differences between SQLMM and SFSQL 1.2 confused me.
The SFSQL 1.2 first says:
MultiSurface is an instantiable class in this Standard, and may be
used to represent heterogeneous surfaces
collections of polygons and polyhedral surfaces.
then it also says
A MultiPolygon is a subtype of the non-instantiable type MultiSurface.
and finally, it includes no specification of MultiSurface for WKT.
Whereas in ISO SQLMM,
The ST_MultiSurface type may be instantiable.
then it specifies WKT (which I copied in my first email)
*but*, AFAIU, that WKT does not allow polyhedral surfaces as part of
MultiSurface, does it?
If my understanding is correct, this is quite a significant difference
between the SQLSF adn SQLMM.
M.
On 10 January 2014 19:08, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Yes, these are types picked up from drafts. polyhedral surface did
> make SFSQL 1.2. haven't seen tin/triangle in anything (which makes me
> less happy that we have them, since they seem to get little enough
> use, and I'm not really convinced they are good ways to model that
> stuff, but water under the bridge...)
> P
> On Fri, Jan 10, 2014 at 5:02 AM, Mateusz Łoskot <mateusz at loskot.net> wrote:
>> Hi,
>> The bnf-wkt.txt [1], with last commit saying "Document ISO WKT/WKB (#1451)"
>> specifies:
>> <multisurface text representation> ::=
>>     MULTISURFACE [ <z m> ] <multisurface text> |
>>     <multipolygon text representation> |
>>     <polyhedralsurface text representation> |
>>     <tin text representation>
>> whereas the ISO/IEC 13249-3 (Date: 2009-01-16) specifies:
>> <multisurface text> ::=
>>      <empty set>
>>    | <left paren> <surface text>
>>       { <comma> <surface text> }... <right paren>
>> <surface text> ::=
>>      CURVEPOLYGON <curvepolygon text body>
>>    | <polygon text body>
>> Why bnf-wkt.txt adds polyhedralsurface and tin to
>> multisurface text representation?
>> Is that PostGIS-specific behaviour?
>> [1] https://github.com/postgis/postgis/blob/svn-trunk/doc/bnf-wkt.txt
>> Best regards,
>> Mateusz  Łoskot, http://mateusz.loskot.net
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
