[postgis-devel] Postgis topology creation - O(n-squared)? - creates problems with large datasets.
Sandro Santilli strk at keybit.net
Tue Jan 14 10:32:55 PST 2014
On Tue, Jan 14, 2014 at 02:52:18PM +0000, Graeme B. Bell wrote:
> > I did up to 160000, after which I stopped because it took ~10 hours,
> > and I've been running twice: once with ST_CreateTopoGeo and once
> > with TopoGeo_addPolygon.
> Sandro,
> Thank you for your excellent work in reproducing the situation and beginning the investigation. I am really curious to see what else you discover.
> BTW, I've checked with my boss and the 'topologish' files are free for use however you like, because they are just random data. Let me know if you want a larger sample later (e.g. 20M polygons) whenever the code is able to handle that many.
Thanks. I wouldn't know where to put them, but they are a really good
test dataset. Will they be stable at the url you gave ?
For now I'm attaching an updated plot showing how using the index
changed the curve. It also shows how TopoGeo_addPolygon performs
better than ST_CreateTopoGeo, even if still running in a single
transaction.  Row numbers (the lines with + are after the fix)
 Rows  | ST_CreateTopoGeo  | TopoGeo_addPolygon |
  5000 |      129427.274   |      116104.691    |
     + |      105686.370   |       92694.196    |
 10000 |      327703.598   |      301611.556    |
     + |      226239.651   |      198670.907    |
 20000 |      936224.702   |      884240.862    |
     + |      526605.369   |      476830.898    |
 40000 |     2976178.984   |     2891650.767    |
     + |     1343630.221   |     1134592.873    |
 80000 |    10343526.099   |    10254117.319    |
     + |     3775123.534   |     3680183.557    |
160000 |    38352283.535   |    38375126.950    |
     + |    12088554.776   |     9644736.277    |
--strk;
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140114/26a68284/attachment.png>
