[postgis-devel] Reg : Error while doing " create extension postgis; "
Daniel Kastl daniel at georepublic.de
Sat Jan 25 20:46:28 PST 2014
Hi Manikanta,
Which version of Ubuntu do you have troubles with?
I remember that last year there was a change in the package naming of
GDAL UbuntuGIS packages. So when I installed PostGIS 2.x it
uninstalled QGIS. Still I have some troubles with Tilemill package for
example, which requires the "original" package.
For pgRouting though this should be resolved. CMake is only too old
for Ubuntu 12.04, but there is a newer version in the pgRouting PPA.
Daniel
On Sun, Jan 26, 2014 at 5:53 AM, Manikanta Kondeti
<mani.iiit123 at gmail.com> wrote:
> Hello sir ,
>       I heard that if add that repositories  cmake wont work & it will
> remove all libraries linked with it . I have done a web application using
> pgrouting in oct & nov , at that time I remember I had these libraries in my
> system and it worked perfectly . In this month I was about to do my lab work
> which needs cmake  , so I installed it again & it removed all the libararies
> linked with pgrouting . I got this information from ubuntu people in IRC. Is
> there any alternative way ,   Now what shall I do ??
> Thank you ,
> Manikanta
> Spatial Informatics ,
> IIIT-H
> On Sat, Jan 25, 2014 at 7:52 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> On 1/25/2014 5:46 AM, Manikanta Kondeti wrote:
>>> Hello ,
>>>       I am getting this error while installing a pgrouting algorithm
>>> which is developed last year . I have also attached a screenshot of it
>>> which shows the error .
>>> Error :    could not load library
>>> "/usr/lib/postgresql/9.1/lib/rtpostgis-2.0.so
>>> <http://rtpostgis-2.0.so>": /usr/local/lib/libgdal.so.1: version
>>> `GDAL_1.8' not found (required by
>>> /usr/lib/postgresql/9.1/lib/rtpostgis-2.0.so <http://rtpostgis-2.0.so>)
>> I would recommend adding adding the following ppa's
>> http://ppa.launchpad.net/georepublic/pgrouting/ubuntu precise
>> http://ppa.launchpad.net/ubuntugis/ppa/ubuntu precise
>> http://apt.postgresql.org/pub/repos/apt/ precise-pgdg
>> This should make the latest gis stack available on Ubuntu.
>> -Steve W
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
