[postgis-devel] Reg : Error while doing " create extension postgis; "
Manikanta Kondeti mani.iiit123 at gmail.com
Mon Jan 27 10:18:12 PST 2014
Thanks for help sir  (Daniel & Steve ) . Its working now .
On Sun, Jan 26, 2014 at 9:04 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Manikanta,
> Looking at your error message again, it looks like you system has a mix of
> code installed from source in /usr/local/lib and some from packages and
> they are getting mixed up.
> I run Ubuntu 12.04 LTS and regularly compile  pgrouting without any
> problem, but I do not have anything in /usr/local/* that might conflict
> with the packages installed.
> -Steve
> >      >>> Error :    could not load library
> >      >>> "/usr/lib/postgresql/9.1/lib/rtpostgis-2.0.so
> >     <http://rtpostgis-2.0.so>
> >      >>> <http://rtpostgis-2.0.so>": /usr/local/lib/libgdal.so.1:
> version
> >      >>> `GDAL_1.8' not found (required by
> >     <http://rtpostgis-2.0.so> <http://rtpostgis-2.0.so>)
> On 1/26/2014 1:53 AM, Manikanta Kondeti wrote:
>> Hello sir ,
>> I'm using Ubuntu 12.04 . I remember that I had same problem  with QGIS
>> last time when I added this repositories. Tillmill is working in my lab
>> system & its not working in my system .  Anyway I will add this
>> repositories  & do my other work in lab . But just tell me if there is
>> any alternative way that I can work on both or should I update to Ubuntu
>> 13.04 ? .
>> Thank you
>> Manikanta
>> Spatial Informatics
>> IIIT-H
>> On Sun, Jan 26, 2014 at 10:16 AM, Daniel Kastl <daniel at georepublic.de
>> <mailto:daniel at georepublic.de>> wrote:
>>     Hi Manikanta,
>>     Which version of Ubuntu do you have troubles with?
>>     I remember that last year there was a change in the package naming of
>>     GDAL UbuntuGIS packages. So when I installed PostGIS 2.x it
>>     uninstalled QGIS. Still I have some troubles with Tilemill package for
>>     example, which requires the "original" package.
>>     For pgRouting though this should be resolved. CMake is only too old
>>     for Ubuntu 12.04, but there is a newer version in the pgRouting PPA.
>>     Daniel
>>     On Sun, Jan 26, 2014 at 5:53 AM, Manikanta Kondeti
>>     <mani.iiit123 at gmail.com <mailto:mani.iiit123 at gmail.com>> wrote:
>>      > Hello sir ,
>>      >       I heard that if add that repositories  cmake wont work & it
>>     will
>>      > remove all libraries linked with it . I have done a web
>>     application using
>>      > pgrouting in oct & nov , at that time I remember I had these
>>     libraries in my
>>      > system and it worked perfectly . In this month I was about to do
>>     my lab work
>>      > which needs cmake  , so I installed it again & it removed all the
>>     libararies
>>      > linked with pgrouting . I got this information from ubuntu people
>>     in IRC. Is
>>      > there any alternative way ,   Now what shall I do ??
>>      > Thank you ,
>>      > Manikanta
>>      > Spatial Informatics ,
>>      > IIIT-H
>>      > On Sat, Jan 25, 2014 at 7:52 PM, Stephen Woodbridge
>>      > <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>      >> On 1/25/2014 5:46 AM, Manikanta Kondeti wrote:
>>      >>> Hello ,
>>      >>>       I am getting this error while installing a pgrouting
>>     algorithm
>>      >>> which is developed last year . I have also attached a
>>     screenshot of it
>>      >>> which shows the error .
>>      >>> <http://rtpostgis-2.0.so>": /usr/local/lib/libgdal.so.1: version
>>      >> I would recommend adding adding the following ppa's
>>      >> http://ppa.launchpad.net/georepublic/pgrouting/ubuntu precise
>>      >> http://ppa.launchpad.net/ubuntugis/ppa/ubuntu precise
>>      >> http://apt.postgresql.org/pub/repos/apt/ precise-pgdg
>>      >> This should make the latest gis stack available on Ubuntu.
>>      >> -Steve W
>>      >> _______________________________________________
>>      >> postgis-devel mailing list
>>      >> postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.
>> osgeo.org>
>>      >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
>> osgeo.org>
>>     Georepublic UG & Georepublic Japan
>>     eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl@
>> georepublic.de>
>>     Web: http://georepublic.de
>>     postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140127/d17d31a8/attachment.html>
