[postgis-devel] Mysteries of PostGIS .jar
maplabs at light42.com maplabs at light42.com
Sun Jul 13 22:50:00 PDT 2014
Hi Baris -
  please note that OSGeo-Live a3 is available, and approaching the
complete set of packages / versions (see below). A very simple README
with a link to an example Java program might be a way to get started..
I can commit the files.  Also, I updated ticket 1310 with some info on
postgis jar that is apparently installed via two packages...
>> .. there is even another jdbc_jtsparser.jar provided to make use  of
>> JTS spatial objects with Postgis Database. When you refer to README
>> are u talking about a README file that describes how to checkout
>> from  svn tag and build jdbc jars out of it. Please let me know the
>> purpose of  the README file and I write it for u.
  hmm The purpose of OSGeo-Live is to demonstrate stable software to
potential users, and potential developers. A simple demonstration
program showing the use of PostGIS .jar would do that. If a sample
program does not exist, even a simple text description of how it might
be actually applied would be helpful too.. as mentioned, I have never
seen any app that uses the PostGIS .jar myself, so most any attention
to this would be an improvement.
I can tell you my larger intention, and perhaps you can reflect how you
see to best accomplish it might be..  I want to make sure that
advances in geospatial java - like the PostGIS java interface to start
- are reflected on OSGeo-Live.  In the distributed processing world,
Java is being used very well to implement processing nodes, and some
companies and projects are starting to claim geospatial capabilities.
https://www.locationtech.org/proposals/spatial4j
and the announcement described here:
http://lists.osgeo.org/pipermail/postgis-users/2014-July/039377.html
  OSGeo-Live dev URLs:
http://aiolos.survey.ntua.gr/gisvm/dev/
Archive-Mirror
  http://osprey.ucdavis.edu/downloads/osgeo/gisvm/gisvm/
Bug List http://trac.osgeo.org/osgeo/report/10
IRC Logs - http://irclogs.geoapt.com/osgeolive
SVN Repository -  https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk
On Mon, 23 Jun 2014 10:25:08  0300, Baris Ergun
<barisergun75 at gmail.com> wrote:
 "*if* the PostGIS .jar as supllied by current repositories, is in
shape to be relied upon, an example or text README specific to the
PostGIS .jar would be welcome."
Yes it is. There is even another jdbc_jtsparser.jar provided to make
use of JTS spatial objects with Postgis Database. When you refer to
README are u talking about a README file that describes how to checkout
Best.
Baris.
On 23 June 2014 07:08,  <maplabs at light42.com> wrote:
To PostGIS Java maintainers/users :
  The OSGeo-Live [1] is in alpha for version 8.0. We have not only
featured PostGIS from the inception of the disk, but also provide
common sample databases for applications to refer to in Documentation
and Quickstart Examples [2]. To date, however, no project on the disk
has used the PostGIS java interfaces (to my knowledge).
  In any case, please consider a visit the OSGeo-Live project, by
mailing list or IRC [3] to comment on this outstanding ticket:
   http://trac.osgeo.org/osgeo/ticket/1310
[1]  http://live.osgeo.org
[2]  http://live.osgeo.org/en/overview/overview.html
[3]  freenode IRC  #osgeolive
http://lists.osgeo.org/mailman/listinfo/live-demo
  thanks very much and here's to yet another excellent OSGeo-Live
release, for FOSS4G-NA 2014
  best regards from Berkeley, California
Brian M Hamlin
OSGeo California Chapter
blog.light42.com
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
Barış
