[postgis-devel] shp2pgsql multi-transaction INSERT mode
Rémi Cura remi.cura at gmail.com
Fri Jul 18 04:32:34 PDT 2014
Cool !
That's probably why it is the fastest way to load shp (faster than gdal).
B-)
For big data I would bet that it is fastest to load with copy then
reproject with transform in base.
Cheers,
Rémi-C
2014-07-18 12:56 GMT+02:00 Sandro Santilli <strk at keybit.net>:
> On Fri, Jul 18, 2014 at 10:36:47AM +0100, Mark Cave-Ayland wrote:
> > On 18/07/14 10:17, Sandro Santilli wrote:
> > >It looks like shp2pgsql doesn't do INSERT in multiple
> > >transactions anymore, but I couldn't figure out since when.
> > >It used to do 250 inserts per transaction around 2004, do
> > >you know when was that changed and why ?
> > Not sure - check the history? However I would definitely have argued
> > to remove this, given as I have personal experience that the time
> > cost of manually sorting through a partial committed shapefile is
> > exponentially larger than failing individual queued shapefiles so
> > you easily know which files you need to retry.
> I agree a single transaction is easier to deal with, but anywa
> given this is a change in behavior I would have expected an entry
> in the NEWS file.
> Maybe it changed during the refactoring toward -core and -cli.
> I guess a comparable speed to the "chunked insert" could be obtained
> by using a single INSERT for multiple rows, like:
>  INSERT INTO target VALUES
>   (row1),
>   (rowX),
>   (row255)
> Remi: shp2pgsql can do boty COPY or INSERT. You can't use COPY when
> reprojecting, which is a reason to use INSERT.
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140718/fea0f493/attachment.html>
