[postgis-devel] Regarding Sp-gist implementation in postgis]
Sandro Santilli strk at keybit.net
Mon Jul 28 06:35:17 PDT 2014
On Mon, Jul 28, 2014 at 05:49:47PM +0530, mohit kumar wrote:
> Reseting the conf file also gives the same output.
> The restored configuration file is as http://pastebin.com/HA5ujeXT
Where is the file ?
How are you invoking PostgreSQL ?
And the error is ?
> Also, in which file the debugging prints need to be inserted? adding prints
> in postgis/sp_gist.c are not working. DO they need to be inserted in
> postgis.sql.in file?
They should work in sp_gist.c, if that code is called.
Show some code.
--strk;
