[postgis-devel] Regarding Sp-gist implementation in postgis]
mohit kumar mohitkharb at gmail.com
Mon Jul 28 09:37:56 PDT 2014
Hi Brian,
My postgresql is building and running fine. The issue coming while using
valgrind for debugging my code. Anyways I will be there on the irc if any
other issue crops up.
Thanks
On Mon, Jul 28, 2014 at 9:15 PM, <maplabs at light42.com> wrote:
> I built and executed a Postgres from source during a code sprint for the
> Postgres project, however it was tricky.  I recall I executed many steps as
> the linux postgres user.
> you can definetly get 24 hour support on building and running postgres
> from source on freenode IRC #postgresql
> I use Firefox Chatzilla plugin.. it is built into SeaMonkey if you want to
> have a really simple way to get Chatzilla.. otherwise install the Chatzill
> extension, restart Firefox, open Chatzilla from Tools menu, click on
> Freenode
> /nick mohitkumar
> /join postgresql
>  -Brian
> On Mon, 28 Jul 2014 17:49:47 +0530, mohit kumar <mohitkharb at gmail.com>
> wrote:
> Reseting the conf file also gives the same output.
> The restored configuration file is as http://pastebin.com/HA5ujeXT
> Also, in which file the debugging prints need to be inserted? adding
> prints in postgis/sp_gist.c are not working. DO they need to be inserted in
> postgis.sql.in file?
> Regards,
> On Mon, Jul 28, 2014 at 4:23 PM, Sandro Santilli <strk at keybit.net> wrote:
>> On Mon, Jul 28, 2014 at 04:05:14PM +0530, mohit kumar wrote:
>> > On 25 Jul 2014 13:13, "Sandro Santilli" <strk at keybit.net> wrote:
>> > > On Fri, Jul 25, 2014 at 08:35:08AM +0530, mohit kumar wrote:
>> > > > file(/usr/local/pgsql/data/postgresql.conf) are pasted at
>> > > > http://pastebin.com/eaX383cw.
>> > > The paths for "hba_file" and "ident_file" and "data_directory" all
>> seem
>> > > to be relative, so would resolve based on where you are when you start
>> > > postgres. As you're starting it from ~/builds/source/postgis, I dubt
>> > > you have ~/builds/source/postgis/ConfigDir, which would explain the
>> error.
>> > The error is coming even after removing the path for hba_file and
>> > ident_file.
>> See if there are other relative paths, paste new config again.
>> Reset the config to default as last resort.
>> Try also another path if this one (valgrind) is too hard for you:
>> add debugging prints into the code to see which parts of the code
>> are executed and which not.
>> Try more things, try harder.
>> --strk;
>>  ()  ASCII ribbon campaign  --  Keep it simple !
>>  /\  http://strk.keybit.net/rants/ascii_mails.txt
> Mohit Kumar
> +91-970-3840-175
> Lab For Spatial Informatics
> International Institute of Information Technology
> Hyderabad, India
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> <http://webmail.light42.com/hwebmail/services/go.php?url=http%3A%2F%2Flists.osgeo.org%2Fcgi-bin%2Fmailman%2Flistinfo%2Fpostgis-devel>
Mohit Kumar
+91-970-3840-175
Hyderabad, India
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140728/94d0149a/attachment.html>
