[postgis-devel] building PostGIS with SFCGAL from source fails
G. Allegri giohappy at gmail.com
Mon Jun 23 15:17:38 PDT 2014
I'm trying to build latest PostGIS (2.2dev) with SFCGAL.
SFCGAL is installed in /usr/local/lib, and includes are in
/usr/local/include/SFCGAL
I've run configure as:
./configure --with-sfcgal=/usr/local/bin
and it finds SFCGAL (even if it doesn't output the version, which should be
1.0.4):
-------------- Compiler Info -------------
  C compiler:           gcc -g -O2
  C++ compiler:         g++ -g -O2
  SQL preprocessor:     /usr/bin/cpp -traditional-cpp -P
 -------------- Dependencies --------------
  GEOS config:          /usr/bin/geos-config
  GEOS version:         3.3.8
  GDAL config:          /usr/bin/gdal-config
  GDAL version:         1.10.0
  SFCGAL config:        /usr/local/bin
  SFCGAL version:
  PostgreSQL config:    /usr/bin/pg_config
  PostgreSQL version:   PostgreSQL 9.1.13
  PROJ4 version:        48
  Libxml2 config:       /usr/bin/xml2-config
  Libxml2 version:      2.8.0
  JSON-C support:       yes
  PostGIS debug level:  0
  Perl:                 /usr/bin/perl
 --------------- Extensions ---------------
  PostGIS Raster:       enabled
  PostGIS Topology:     enabled
  SFCGAL support:       enabled
Everything seems ok, but it fails during the linking of utilities (e.g.
raster loader or, in case a disable raster, during shp2pgsql building):
/bin/bash ../libtool --mode=link \
  gcc -I ../liblwgeom -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes
 shpopen.o dbfopen.o getopt.o shpcommon.o safileio.o shp2pgsql-core.o
shp2pgsql-cli.o ../liblwgeom/liblwgeom.la -o shp2pgsql  -lc
libtool: link: gcc -I ../liblwgeom -g -O2 -fPIC -DPIC -Wall
-Wmissing-prototypes shpopen.o dbfopen.o getopt.o shpcommon.o safileio.o
shp2pgsql-core.o shp2pgsql-cli.o -o .libs/shp2pgsql
 ../liblwgeom/.libs/liblwgeom.so -lc -Wl,-rpath
-Wl,/home/giova/bin/postgis/lib
../liblwgeom/.libs/liblwgeom.so: undefined reference to
`sfcgal_solid_num_shells'
../liblwgeom/.libs/liblwgeom.so: undefined reference to `sfcgal_point_y'
../liblwgeom/.libs/liblwgeom.so: undefined reference to `sfcgal_point_x'
`sfcgal_geometry_collection_geometry_n'
`sfcgal_linestring_point_n'
`sfcgal_polyhedral_surface_polygon_n'
`sfcgal_triangle_set_vertex_from_xyz'
`sfcgal_solid_shell_n'
`sfcgal_solid_create_from_exterior_shell'
(and other similar undefined references)
What's going wrong? Why liblwgeom linking
I past also the readelf output run on liblwgeom.so
Thanks for your precious help,
Giovann
00066048  00000107 R_386_JUMP_SLOT        00000000   sfcgal_solid_num_shells
000660d0  00000a07 R_386_JUMP_SLOT        00000000
sfcgal_linestring_add_point
00066174  00001407 R_386_JUMP_SLOT        00000000
sfcgal_linestring_num_points
000661a4  00001707 R_386_JUMP_SLOT        00000000   sfcgal_point_y
000661c8  00001907 R_386_JUMP_SLOT        00000000
sfcgal_geometry_collection_num_geometries
00066260  00002207 R_386_JUMP_SLOT        00000000   sfcgal_triangle_vertex
00066380  00002f07 R_386_JUMP_SLOT        00000000
00066390  00003007 R_386_JUMP_SLOT        00000000
sfcgal_polygon_interior_ring_n
000663d0  00003407 R_386_JUMP_SLOT        00000000
00066484  00003e07 R_386_JUMP_SLOT        00000000
00066490  00004007 R_386_JUMP_SLOT        00000000   sfcgal_version
000664b8  00004407 R_386_JUMP_SLOT        00000000
sfcgal_polygon_exterior_ring
000664ec  00004707 R_386_JUMP_SLOT        00000000
sfcgal_point_create_from_xy
000664f4  00004807 R_386_JUMP_SLOT        00000000
sfcgal_geometry_collection_add_geometry
00066540  00004e07 R_386_JUMP_SLOT        00000000
sfcgal_linestring_create
000665d8  00005807 R_386_JUMP_SLOT        00000000
0006663c  00005d07 R_386_JUMP_SLOT        00000000   sfcgal_geometry_is_3d
00066660  00006007 R_386_JUMP_SLOT        00000000
sfcgal_geometry_is_empty
000666a0  00006407 R_386_JUMP_SLOT        00000000
sfcgal_multi_linestring_create
000666b8  00006707 R_386_JUMP_SLOT        00000000   sfcgal_point_x
000666d0  00006907 R_386_JUMP_SLOT        00000000   sfcgal_point_z
000666ec  00006a07 R_386_JUMP_SLOT        00000000
00066738  00007007 R_386_JUMP_SLOT        00000000
0006673c  00007107 R_386_JUMP_SLOT        00000000
sfcgal_multi_point_create
00066744  00007207 R_386_JUMP_SLOT        00000000   sfcgal_polygon_create
0006678c  00007807 R_386_JUMP_SLOT        00000000
sfcgal_multi_polygon_create
00066790  00007907 R_386_JUMP_SLOT        00000000   sfcgal_geometry_type_id
000667cc  00007d07 R_386_JUMP_SLOT        00000000
sfcgal_polyhedral_surface_add_polygon
000667d4  00007e07 R_386_JUMP_SLOT        00000000
sfcgal_polygon_num_interior_rings
000667fc  00007f07 R_386_JUMP_SLOT        00000000
sfcgal_geometry_collection_create
00066800  00008007 R_386_JUMP_SLOT        00000000
sfcgal_polygon_add_interior_ring
0006680c  00008307 R_386_JUMP_SLOT        00000000
sfcgal_polygon_create_from_exterior_ring
000668b8  00008e07 R_386_JUMP_SLOT        00000000
sfcgal_point_create_from_xyz
000668d0  00008f07 R_386_JUMP_SLOT        00000000
sfcgal_polyhedral_surface_create
0006694c  00009607 R_386_JUMP_SLOT        00000000   sfcgal_triangle_create
0006697c  00009907 R_386_JUMP_SLOT        00000000
sfcgal_triangulated_surface_create
0006699c  00009b07 R_386_JUMP_SLOT        00000000
sfcgal_triangulated_surface_num_triangles
000669d4  00009c07 R_386_JUMP_SLOT        00000000
sfcgal_triangulated_surface_triangle_n
000669e0  00009d07 R_386_JUMP_SLOT        00000000   sfcgal_geometry_delete
000669ec  00009e07 R_386_JUMP_SLOT        00000000
sfcgal_polyhedral_surface_num_polygons
00066a4c  0000a507 R_386_JUMP_SLOT        00000000
sfcgal_triangulated_surface_add_triangle
00066a64  0000a707 R_386_JUMP_SLOT        00000000   sfcgal_point_create
00066a6c  0000a807 R_386_JUMP_SLOT        00000000   sfcgal_solid_shell_n
     1: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_solid_num_shells
    10: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
    20: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
    23: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_point_y
    25: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
    34: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_triangle_vertex
    47: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
    48: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
    52: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
    62: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
    64: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_version
    68: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
    71: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
    72: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
    78: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_linestring_create
    88: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_linestring_point_n
    93: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_geometry_is_3d
    96: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_geometry_is_empty
   100: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   103: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_point_x
   105: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_point_z
   106: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   112: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   113: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_multi_point_create
   114: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_polygon_create
   120: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   121: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_geometry_type_id
   125: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   126: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   127: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   128: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   131: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   142: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   143: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   150: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_triangle_create
   153: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   155: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   156: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   157: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_geometry_delete
   158: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   165: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
   167: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_point_create
   168: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_solid_shell_n
   543: 0004be90    25 FUNC    GLOBAL DEFAULT   11 lwgeom_sfcgal_version
   758: 0004c840   198 FUNC    GLOBAL DEFAULT   11 lwgeom_sfcgal_noop
   923: 00000000     0 FILE    LOCAL  DEFAULT  ABS lwgeom_sfcgal.c
   989: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_solid_num_shells
  1030: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1079: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1095: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_point_y
  1105: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1162: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_triangle_vertex
  1255: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1263: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1286: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1312: 0004c840   198 FUNC    GLOBAL DEFAULT   11 lwgeom_sfcgal_noop
  1343: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1348: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_version
  1362: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1383: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1386: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1412: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_linestring_create
  1464: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_linestring_point_n
  1492: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_geometry_is_3d
  1497: 0004be90    25 FUNC    GLOBAL DEFAULT   11 lwgeom_sfcgal_version
  1503: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_geometry_is_empty
  1522: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1533: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_point_x
  1542: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_point_z
  1549: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1575: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1577: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_multi_point_create
  1580: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_polygon_create
  1600: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1601: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_geometry_type_id
  1618: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1621: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1635: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1636: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1639: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1696: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1703: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1743: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_triangle_create
  1759: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1770: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1788: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1791: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_geometry_delete
  1794: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1825: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND
  1831: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_point_create
  1833: 00000000     0 NOTYPE  GLOBAL DEFAULT  UND sfcgal_solid_shell_n
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/_giohappy_
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140624/c2b36fa0/attachment.html>
