[postgis-devel] [SoC] "Gsoc weekly report 4": Implement sp-gist clustering in PostGIS and cartoDB
mohit kumar mohitkharb at gmail.com
Wed Jun 25 03:26:58 PDT 2014
Hi Sandro,
I have updated the trunk branch in my system already. Not able to send the
pull request as I have cloned the svn-trunk branch in my system. I dont
have my branch so not able to make a pull request. or should I push the
code on the "svn-trunk" branch?
Regards,
On Wed, Jun 25, 2014 at 3:25 PM, Sandro Santilli <strk at keybit.net> wrote:
> Mohit, any news about sp-gist indexes support on Geometry ?
> Midterm evaluation is due in 2 days ...
> I'm looking forward for a pull request adding that.
> --strk;
> On Wed, Jun 18, 2014 at 07:11:26PM +0530, mohit kumar wrote:
> > Thanks Strk,
> > Will revert back to you in a day.
> > Regards,
> > Mohit
> > On Jun 18, 2014 6:56 PM, "Sandro Santilli" <strk at keybit.net> wrote:
> > > On Wed, Jun 18, 2014 at 06:05:34PM +0530, mohit kumar wrote:
> > > > Hi Strk,
> > > > Can you give me some references on how to write a postGIS connector
>  and
> > > > what exactly do we want. I am getting confused in a lot of things.
> > > We want to be able to do:
> > > CREATE INDEX ON the_table USING spgist (the_geom);
> > > Then, (second step?):
> > > -- This query should use the spgist index
> > > EXPLAIN SELECT * FROM the_table WHERE the_geom && <small_bbox>;
> > > --strk;
Mohit Kumar
+91-970-3840-175
Lab For Spatial Informatics
International Institute of Information Technology
Hyderabad, India
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140625/64169bfa/attachment.html>
