[postgis-devel] Contributing via pull requests (was: "Gsoc weekly report 4": Implement sp-gist) clustering in PostGIS and cartoDB
mohit kumar mohitkharb at gmail.com
Wed Jun 25 04:27:44 PDT 2014
Hi sandro,
I have forked the postgis repository at
https://github.com/mohitkharb/postgis and am creating a pull request but
its not happening.
On Wed, Jun 25, 2014 at 4:26 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Wed, Jun 25, 2014 at 03:56:58PM +0530, mohit kumar wrote:
> > Hi Sandro,
> > I have updated the trunk branch in my system already. Not able to send
> the
> > pull request as I have cloned the svn-trunk branch in my system. I dont
> > have my branch so not able to make a pull request. or should I push the
> > code on the "svn-trunk" branch?
> I guess you mean you don't have your github fork ?
> I'd recommend getting an online repository to easy operations in the
> future.
> Doesn't need to be on github, as long as I can access your branch :)
> hint: https://gitorious.org/
> Anyway for this time you could use git-format-patch(1).
> For example:
>   git format-patch origin/svn-trunk
> Or even git diff:
>   git diff origin/svn-trunk > spgist.patch
> And attach the patch to the trac ticket:
> http://trac.osgeo.org/postgis/ticket/1847
> Note that git-format-patch would create a patch for each and every commit.
> I'd prefer a single file instead. You could squash-rebase your local branch
> against current official "svn-trunk" to obtain the single-file patch, which
> would be also recommended for the patch (to ensure it applies cleanly)
> Let me know if you need any help with git.
> Consider also asking in the #git IRC channel on freenode.
> --strk;
> > On Wed, Jun 25, 2014 at 3:25 PM, Sandro Santilli <strk at keybit.net>
> wrote:
> > > Mohit, any news about sp-gist indexes support on Geometry ?
> > > Midterm evaluation is due in 2 days ...
> > > I'm looking forward for a pull request adding that.
> > > --strk;
> > > On Wed, Jun 18, 2014 at 07:11:26PM +0530, mohit kumar wrote:
> > > > Thanks Strk,
> > > > Will revert back to you in a day.
> > > > Regards,
> > > > Mohit
> > > > On Jun 18, 2014 6:56 PM, "Sandro Santilli" <strk at keybit.net> wrote:
> > > > > On Wed, Jun 18, 2014 at 06:05:34PM +0530, mohit kumar wrote:
> > > > > > Hi Strk,
> > > > > > Can you give me some references on how to write a postGIS
> connector
> > >  and
> > > > > > what exactly do we want. I am getting confused in a lot of
> things.
> > > > > We want to be able to do:
> > > > > CREATE INDEX ON the_table USING spgist (the_geom);
> > > > > Then, (second step?):
> > > > > -- This query should use the spgist index
> > > > > EXPLAIN SELECT * FROM the_table WHERE the_geom && <small_bbox>;
> > > > > --strk;
> > Mohit Kumar
> > +91-970-3840-175
> > Lab For Spatial Informatics
> > International Institute of Information Technology
> > Hyderabad, India
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
>  ()  ASCII ribbon campaign  --  Keep it simple !
>  /\  http://strk.keybit.net/rants/ascii_mails.txt
Mohit Kumar
+91-970-3840-175
Hyderabad, India
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140625/6022e6a2/attachment.html>
