[postgis-devel] ST_Intersection failing on valid geometries
Komяpa me at komzpa.net
Fri Jun 27 03:18:54 PDT 2014
I managed to create a set of geometries that I'd like to intersect.
POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0,
6 March 2012" GDAL="GDAL 1.11.0, released 2014/04/16" LIBXML="2.9.1"
LIBJSON="UNKNOWN" (core procs from "2.1.2 r12389" need upgrade)
TOPOLOGY (topology procs from "2.1.2 r12389" need upgrade) RASTER
(raster procs from "2.1.2 r12389" need upgrade)
Test table:
http://pastebin.com/qSYLGfvs
After that:
select ST_Intersection(p.geom, g.geom) from bad_intersections p,
bad_intersections g;
ERROR:  XX000: Error performing intersection: TopologyException: found
non-noded intersection between LINESTRING (1.45784e+07 -1.40333e+06,
1.45784e+07 -1.40333e+06) and LINESTRING (1.45784e+07 -1.40333e+06,
1.45784e+07 -1.40333e+06) at 14578380.693885569 -1403332.55464
Time: 10,674 ms
All geometries are valid.
Can this be fixed?
Darafei "Komяpa" Praliaskouski
OSM BY Team - http://openstreetmap.by/
xmpp:me at komzpa.net mailto:me at komzpa.net
