[postgis-devel] install-sh
Paul Ramsey pramsey at cleverelephant.ca
Mon Jun 30 08:29:56 PDT 2014
And yes, I think we could safely remove it (maybe) and things would still work (probably)
P
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On June 30, 2014 at 7:06:17 AM, Sandro Santilli (strk at keybit.net) wrote:
Every time I run ./autogen.sh the "install-sh" file, which is
found in the repository, gets re-written. The most notable
change is:
-scriptversion=2011-01-19.21; # UTC
+scriptversion=2011-11-20.07; # UTC
So I must have something newer than whoever committed the file
in the repository had.
A couple of questions arise:
1) Should that file really be in the repository ?
We require to run ./autogen.sh anyway right after getting a copy of the
codebase from the SVN repository, so it would be recreated locally
According to r9062 (Feb 2012), the file was re-added in the repository
(after removing it at r9061) to support libtool < 2.0
Current debian stable ships libtool version 2.4.2:
https://packages.debian.org/it/wheezy/libtool
Should we re-remove it ?
2) Does it start a commit war to commit the new version, if we have to
keep the file ? Regina on IRC already confirmed she gets the new
version too. Does anyone else have experience of running ./autogen.sh
NOT changing "install-sh" file ?
--strk;
()  ASCII ribbon campaign -- Keep it simple !
/\  http://strk.keybit.net/rants/ascii_mails.txt
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140630/ec23e6ec/attachment.html>
