[postgis-devel] Implement New Geometry Index Method?
Alexander Korotkov aekorotkov at gmail.com
Wed May 21 06:12:50 PDT 2014
On Wed, May 21, 2014 at 1:02 PM, Jeremy Palmer <JPalmer at linz.govt.nz> wrote:
>  Hi PostGIS Devs,
> I have a daily process that I would like to optimise. The process includes
> a spatial intersects join between a small administration boundaries table
> for New Zealand that contains large geometries (100,000+ points per
> polygon) and a large dataset with small line strings.
> The first iteration of SQL I developed for the process I used standard
> join (WHERE ST_Interesects(admin.geom, other.geom)) and it took 4 hours to
> complete. No spatial index was used. Not acceptable.
So, your task is so-called "spatial join". We are now doing researches on
it. It would be nice if you could share your dataset so we can do
experiments on it.
With best regards,
Alexander Korotkov.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140521/a25e0b44/attachment.html>
