[postgis-devel] Implement New Geometry Index Method?
Jeremy Palmer JPalmer at linz.govt.nz
Wed May 21 11:59:23 PDT 2014
> So, your task is so-called "spatial join". We are now doing researches on it. It would be nice if you could share your dataset so we can do experiments on it.
The dataset can be accessed here via web service here: http://maps.stats.govt.nz/wss/service/arcgis1/guest/Boundaries/2013_Geographies/MapServer/9?where=1=1&f=json
Cheers
Jeremy
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
