[postgis-devel] ST_OrderingEquals and memcmp
Paul Ramsey pramsey at cleverelephant.ca
Mon Nov 17 09:32:07 PST 2014
You mean dropping out all the code for orderingequals? I’m a bit leary of that, yes. Particularly since there’s some things like optionality of bounding boxes which are not tightly controlled and could easily lead to false results.
P.
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On November 17, 2014 at 9:29:32 AM, Sandro Santilli (strk at keybit.net) wrote:
On Mon, Nov 17, 2014 at 09:03:49AM -0800, Paul Ramsey wrote:
> There’s only one pad hole, it's for polygons with an odd number of rings. I don’t know why it wouldn’t be consistently zero’ed out, since the pad is set with
> memset(loc, 0, sizeof(uint32_t));
The failure I saw was with point, some test under sfcgal.
But maybe it was my own implementation failing.
Shall I re-try and push the change as soon as it succeeds here ?
Would you like such a dropping-code change ?
In git terms:
1 file changed, 5 insertions(+), 26 deletions(-)
--strk;
> Paul Ramsey
> http://postgis.net
> On November 17, 2014 at 7:12:49 AM, Sandro Santilli (strk at keybit.net) wrote:
> I was reading the implementation of ST_OrderingEquals and wondered
> why we're not using memcmp on the serialized memory.
> Saint testsuite revealed it can sometime fail.
> I guess the reason for that is some "holes" in the serialized format
> left for alignment purpose, does it sound correct ?
> Could we ensure serializers fill any hole to speedup identity checking ?
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20141117/feb980bf/attachment.html>
