[postgis-devel] Address_standardizer extension fully integerated into configure and set to auto-build
Sandro Santilli strk at keybit.net
Wed Oct 8 03:49:23 PDT 2014
On Tue, Oct 07, 2014 at 11:37:31PM -0400, Paragon Corporation wrote:
> More a note for Steve and PostGIS devs to check my work make sure I didn't
> do any damage.
Works for me (I do have PCRE installed).
> The new configure output will look like below (note the PCRE support and
> Address Standardizer support sections)
>  --------------- Extensions ---------------
>   PostGIS Raster:       enabled
>   PostGIS Topology:     enabled
>   SFCGAL support:       disabled
>   Address Standardizer support:       enabled
It would be nice to have a shorter name, and still make
all the enabled/disable strings aligned :)
> I think I have a --without-address_standardizer if for whatever reason
> people run into problems and need to turn it off.  I didn't test that though
> so haven't documented it yet. Not sure if its even needed.
This did not work. You were using "address_standardizer" as a variable but
the variable name would be "with_address_standardizer". I've fixed with
r13051, you can now document "--without-address-standardizer" (all dashes,
no underscores).
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
