[postgis-devel] 2.2 Discussion (a)
Paragon Corporation lr at pcorp.us
Thu Apr 30 15:06:09 PDT 2015
Okay I marked the ones I think I can get done as high or blocker.  Here is
our much shorter list:
http://trac.osgeo.org/postgis/query?priority=high&priority=blocker&status=as
signed&status=new&status=reopened&milestone=PostGIS+2.2.0&order=priority&rep
ort=28
Relisted here-- at cursory glance -- I'm not seeing any of Nicklas stuff
(Nicklas I know you have some stuff brewing almost done but not completely
finished so mark them up),  Also not seeing the sfcgal patch.
	#2305 	Document sfcgal functions and amendment notes for existing
colivier
	#2914 	[raster] ST_Rescale: Could not create GDAL transformation
object for output dataset creation 	dustymugs
	#3096 	PostgreSQL 9.5 regress failure raster 	dustymugs  (I need
to recheck this one, may not be an issue anymore)
	#1024 	Change 3D relationship functions to use &&& in addition to
&& 	pramsey
	#1847 	spgist 2d bindings for geometry 	pramsey
	#2263 	[raster] Audit usage of serialize/deserialize vs wkb/hexwkb
dustymugs
	#2283 	shp2pgsql may be parsing shp's multipolygon incorrectly
mcayland
	#2287 	--enable-debug builds are way too verbose 	pramsey
	#2316 	Setup buildbot jobs to test sfcgal 	robe
	#2358 	Add post-check phase to PostGIS build (installcheck) 	strk
	#2400 	Add more documentation about address_standardizer extension
robe
	#2422 	geography regression difference ST_DWithin 	pramsey
	#2459 	Speed up pagc_normalize_address 	robe
	#2717 	st_numPoints, st_PointN, st_startPoint and st_endPoint full
support on curved geoms 	pramsey
	#2734 	TIGER geocoder gives no results with omitted zipcode 	robe
	#2737 	[PATCH] Upgrade of spatial_ref_sys.sql to EPSG v8.5 	robe
	#2816 	Create data extension for address_standardizer 	woobri
	#2838 	Finish up X3D implementation for all types 	robe
	#2840 	Support X3D Geospatial Component in ST_AsX3D function 	robe
	#2867 	Can't upgrade sfcgal extension 	robe
	#2877 	Revise configure to build make scripts for
address_standardizer extension 	robe
	#2906 	Update to work with tiger 2014 data 	robe
	#2980 	directional as a street name should not be abbreviated 	robe
	#2981 	standardize address returns no answer for particular highway
woobri
Thanks,
Regina
-----Original Message-----
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Thursday, April 30, 2015 2:09 PM
To: PostGIS Development Discussion
Subject: [postgis-devel] 2.2 Discussion (a)
Hey devs,
I'd like to talk through getting 2.2 out in a reasonable time frame, that
means
(a) identifying the major pieces of work we individually hope to have in the
release
(b) agreeing on a feature freeze date
(c) committing to work our particular ticket lists, triaging in particular
and closing what can be closed
Can we start with (a) today: what pieces of development do you hope to
include in 2.2?
Thanks,
P.
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
