[postgis-devel] Help? 'No package postgis2_93 available'
Devrim GÜNDÜZ devrim at gunduz.org
Wed Aug 5 00:46:18 PDT 2015
You need to install repo file first:
http://yum.postgresql.org/repopackages.php#pg93
Then, you can install this package.
Regards, Devrim
On Tue, 2015-08-04 at 18:57 -0700, Quais Afzali wrote:
> Hello,
> I tried googling around and digging around the docs on site, to no
> avail.
> Really hoping someone on this alias can help, as I've hit a pretty
> bad wall
> here..
> Basically, I'm simply trying to install postgis on my Centos 6x64
> box,
> using:
> *'yum install postgis2_93'*
> as detailed in the docs (I'm already running Postgres 9.3 on it).
> This,
> however, gives me the following:
> [quais at server ~]$ *sudo yum install postgis2_93*
> Loaded plugins: fastestmirror
> Setting up Install Process
> Loading mirror speeds from cached hostfile
>  * base: ftpmirror.your.org
>  * extras: mirrors.cmich.edu
>  * updates: cosmos.cites.illinois.edu
> *No package postgis2_93 available.*
> Error: Nothing to do
> Any insight as to what I could be doing wrong?
> Any help much appreciated!
> Quais.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
Devrim GÜNDÜZ
Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
Twitter: @DevrimGunduz , @DevrimGunduzTR
