[postgis-devel] how to add my JTS in postgis?
xschen
xschen at clustertech.com
Sat Aug 8 05:12:17 PDT 2015
thank u,
you mean, postgis uses the GEOS which was installed in my Linux?
can i modify the configuration of postgis, to let it use a specefied dir?
or download the source code(where?) of postgis and compile it.
On 08/08/2015 08:05 AM, Sandro Santilli wrote:
> On Sat, Aug 08, 2015 at 07:59:16AM -0400, xschen wrote:
>> I download the JTS source code , and add an algrithem in it.
>> now , i want to remove the pervious JTS of postgis and add my JTS
>> into it to test.
>> how to?
> You didn't understand what I said.
> PostGIS does NOT use JTS directly.
> Rather, it uses GEOS, which is a port of JTS.
> By running "make install" in the GEOS source dir (after ./configure)
> you should automatically get PostGIS to use the new version.
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
