[postgis-devel] update topology locally
Sandro Santilli strk at keybit.net
Mon Feb 16 10:25:54 PST 2015
On Mon, Feb 16, 2015 at 07:04:45PM +0100, RĂ©mi Cura wrote:
>    (Batch creation from linestring:
>    node with GEOS,A
>    insert node into topology
>    cut linestring into pieces with nodes (various option, GEOS would be best)
>    insert linestring pieces as edge, with only start_node and end_node
>    correct
>    compute edge_linking and face-linking
>    I already have everything in yellow.
Pity neither ASCII nor UTF8 have provision for colors :)
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
