[postgis-devel] Geometry clustering functions
Paul Ramsey pramsey at cleverelephant.ca
Thu Jan 15 14:22:49 PST 2015
Do we want to go the “Accum” naming route, or introduce a “cluster” work?
ST_ClusterWithinDistance
Also, since the intersecting cluster is just the withindistance with a tolerance of zero, would having just one function be good or bad?
P.
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On January 15, 2015 at 2:07:24 PM, Daniel Baston (dbaston at gmail.com) wrote:
Glad to hear there is some interest!  I posted some ideas to http://trac.osgeo.org/postgis/wiki/DevClusteringFunctions
Thanks,
Dan
On Thu, Jan 15, 2015 at 12:28 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
Daniel,
This is interesting stuff, could you post some example function signature and input/output pictures on the wiki so we can do a little design review. I thing it’s very exciting and am very positive about it.
P
Paul Ramsey
http://postgis.net
On January 15, 2015 at 4:14:44 AM, Daniel Baston (dbaston at gmail.com) wrote:
Hello,
I'm working on a couple of C-language functions to solve some clustering problems I frequently face in PostGIS.  I'm wondering if there may be any level of interest in including such functions in the project?  I would be happy to flesh these out to include the error-handling and unit-testing that would be required.
Function #1 takes a GeometryCollection and returns the same geometries, re-aggregated into groups of interconnected geometries (solving a question I posted about at http://gis.stackexchange.com/q/94203 )
(Internally this builds an STRtree using GEOS and uses a union-find structure to identify connected components....as an aside, I am wondering if there is some way to take advantage of a database spatial index that may already exist)
Function #2 (not written) would solve a related problem - we want to take a set of points and return a set of MultiPoints, where each point in a MultiPoint is within distance X of some other point in the MultiPoint.
Thanks,
Dan
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150115/6db2a20b/attachment.html>
