[postgis-devel] shadow and highlights in documentation images
Brian M Hamlin maplabs at light42.com
Thu Jan 22 09:30:49 PST 2015
     is i possible to make a lighter / more transparent shadow then?
  (I think the shadows add to the documentation overall)
On Thu, 22 Jan 2015 17:56:46 +0100, Sandro Santilli <strk at keybit.net> wrote:
I find the images in the doc for ST_Split pretty unreadable:
  > http://postgis.net/docs/ST_Split.html
  > I think it is due to the shadow making it hard to see the polygon
  > stroke, which is what ST_Split currently works on, but there's no
  > way to enable/disable shadow from the styles.conf.
  > Is it ok to drop the shadow (and highlight) from all images or
  > do you think it should be a configuration like it is for colors
  > and such ?
  > --strk;
  > () Free GIS & Flash consultant/developer
  > /\ http://strk.keybit.net/services.html
  > postgis-devel mailing list
  > postgis-devel at lists.osgeo.org
  > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
Brian M Hamlin
  OSGeo California Chapter
  blog.light42.com
