[postgis-devel] [postgis-users] Extension upgrade has no update path 2.1.1 to 2.1.7
Paragon Corporation
lr at pcorp.us
Tue Jul 21 23:22:05 PDT 2015
Paul,
I just checked my build and I have a 2.1.1-2.1.7.sql so whatever the issue is I don't think is a bug in PostGIS.
Can you check your share/extension folder of your postgresql install and verify that you do have a file called postgis-2.1.1--2.1.7.sql ?
I suspect you don't. If you do have all the postgis extension files you should also have a file called postgis--2.1.7.sql
Did you build PostGIS yourself or got from a distribution? Could be a packaging flaw that you need to report to the package maintainer that you are missing extension files.
Thanks,
Regina
http://www.postgis.us
http://postgis.net
-----Original Message-----
From: postgis-devel-bounces at lists.osgeo.org [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
Sent: Tuesday, July 21, 2015 12:11 PM
To: Moen, Paul T. <pmoen at nd.gov>
Cc: postgis-devel at lists.osgeo.org
Subject: Re: [postgis-devel] [postgis-users] Extension upgrade has no update path 2.1.1 to 2.1.7
On Mon, Jul 20, 2015 at 08:25:04PM +0000, Moen, Paul T. wrote:
> I am upgrading from postgis 2.1.1 to 2.1.7 using extensions.
> After entering the following,
> ALTER EXTENSION postgis UPDATE TO "2.1.7�;
> I get error
> ERROR: extension "postgis" has no update path from version "2.1.1" to version "2.1.7"
Sounds like a bug, could you please file it on trac ?
http://trac.osgeo.org/postgis/
--strk;
postgis-devel mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
