[postgis-devel] For PostGIS 2.2 moving forward make liblwgeom compatible between micro releases
Sandro Santilli strk at keybit.net
Thu Jul 30 08:21:07 PDT 2015
On Thu, Jul 30, 2015 at 05:09:00PM +0200, Sebastiaan Couwenberg wrote:
> I don't think linking the libtool version-info to the postgis version in
> this way is correct. The changes in r13855 for PostGIS 2.18 result in
> -version-info 3:1:8 which is an invalid value as documented in the
You might have misread the code.
For version 2.1.8, the version info would be 3:8:1,
as in <current>:<revision>:<age>
> I sugges to start with -version-info 2:0:0 in PostGIS 2.2.0, and keep
> the libtool versioning of liblwgeom separate from the PostGIS version.
It might be better to postpone this to when liblwgeom gets
its own release cicle.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
