[postgis-devel] I want to add an algorithem into postgis
xschen xschen at clustertech.com
Fri Jul 31 16:02:39 PDT 2015
hello, every one.
I am a user of postgis, and  found postgis is very slow when running
st_intersects, st_within st_contains functions on a polygon which
contents many vertex , even has gist index on geometry.
for example: polygon A,B has ten thousands points, A is very big, B is
very small, and B is in the center of A. that is very easy to know B
inside A, but postgis spends sevel seconds to calculate.
I found the intersects algorithem like this:
bool intersects(geometry g1, geometry g2){
     if(!g1.getEnvelope().intersects(g2.getEnvelope())){
         return false;
     }else{
         //calculate its details
I have an ideal to improve its performance:
     if( !g1.getEnvelope().intersects(g2.getEnvelope() ){
         return false;
     }else{
         if(g1.getInnerCircle().intersects(g2.getInnerCircle() ){  //
"getInnerCircle()" returns the biggest circle inside the polygon
             return true;
         }else{
. so that, can improve its performance.
besides, I have an amazing method to calculate the "biggest inner
circle" of an polygon very fast , by using a complex function "magic".
the method is too diffcult to explain in email.
I am just begining to develop the postgis. I dont know its architecture,
and I am solo.
would someone please guide me? introduce the architecture of postgis.
