[postgis-devel] pg9.5 setup
Paul Ramsey pramsey at cleverelephant.ca
Fri Jun 5 10:17:22 PDT 2015
I dunno Brian, I’m running off git tip too, and my pgxs file is right where it’s supposed to be
  /opt/pgsql/9.5/lib/pgxs/src/makefiles/pgxs.mk
Seems like your pg_config is looking in the right place, but it’s not there… my configure is just this..
CFLAGS="-O0 -g" \
./configure \
--enable-debug \
--enable-cassert \
--prefix=/opt/pgsql/${VERSION}/ \
--with-libxml \
--enable-nls \
--with-openssl \
--with-libraries=/opt/local/lib \
--with-includes=/opt/local/include
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On June 5, 2015 at 10:14:22 AM, Brian M Hamlin (maplabs at light42.com) wrote:
Hi -
  I built postgres 9.5 trunk and am running it, alongside the postgis dev setup on debian 8 VM
  * configure
CFLAGS='-g' ./configure --with-python --with-pgport=5433 --enable-debug --enable-cassert --disable-rpath --prefix=/usr/local/pg95
  * init the db as an ordinary user
  * set shell variables PGPORT and PGHOST  (must specify localhost)
  * connect with either psql or psql 9.5dev
works fine
  however,  when I went to rebuild postgis using the 9.5 pg_config
user at debian8:/home/shared/srcs_db8/postgis_22_git $
  CFLAGS='-g' ./configure --with-pgconfig=/usr/local/pg95/bin/pg_config --enable-profile
I get a configure error msg ..
Using user-specified pg_config file: /usr/local/pg95/bin/pg_config
configure: error: the PGXS Makefile /usr/local/pg95/lib/pgxs/src/makefiles/pgxs.mk cannot be found. Please install the PostgreSQL server development packages and re-run configure.
  I built from postgres git trunk.. what else do I need to do ?
Brian M Hamlin
OSGeo California Chapter
blog.light42.com
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150605/cda1b104/attachment.html>
