[postgis-devel] pg9.5 setup
Sandro Santilli strk at keybit.net
Fri Jun 5 11:25:03 PDT 2015
On Fri, Jun 05, 2015 at 10:53:35AM -0700, Brian M Hamlin wrote:
> Do I want to add something else to the postgis config, or, is it a non-issue
> since the lwgeom into /usr/local/lib is the same for both pg9.4 and pg9.5dev
It's a non-issue, liblwgeom is independent from PostgreSQL.
--strk;
