[postgis-devel] liblwgeom dir vs postgis dir
Sandro Santilli strk at keybit.net
Fri Jun 5 15:01:14 PDT 2015
On Fri, Jun 05, 2015 at 02:24:28PM -0700, Brian M Hamlin wrote:
>     what is the difference between postgis/lwgeom_geos.c and
>  liblwgeom/lwgeom_geos.c  ?
The one in liblwgeom is part of liblwgeom, the one in postgis/
is just available in postgis (and may use the liblwgeom part).
> code goes into both, and must match, and both get committed ?
No match, different code, both part of the repository
(you should be able to tell what is part of the repository using
RCS commands, like "git ls-tree HEAD <file>")
--strk;
