[postgis-devel] POINT EMPTY in database dumps (EWKB)
Paul Ramsey pramsey at cleverelephant.ca
Tue Mar 17 11:48:04 PDT 2015
Thought of two other ways to represent POINT EMPTY when asked for the EWKB:
POINT(NaN NaN)
NULL
Neither is ideal, but each at least matches the type of the original,
so wouldn't cause the constraint failure we have here.
On Tue, Mar 17, 2015 at 11:44 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> http://trac.osgeo.org/postgis/ticket/3031
> I didn’t anticipate this *particular* problem when hacking the POINT EMPTY solution (which is to emit MULTIPOINT EMPTY (really, a WKB multipoint with zero members)).
> The only solution I can see would be to add an arbitrary additional WKB type number for the extended WKB format and use that exclusively to handling POINT EMPTY. That would allow dump/restore to work. For anyone who is requesting extended WKB and consuming it though, it would be a breaking change as this (surprise!) new WKB type number shows up in the stream.
> Thoughts?
> P
> http://postgis.net
> http://cleverelephant.ca
