[postgis-devel] Public Raster C API
Nathaniel Clay clay.nathaniel at gmail.com
Wed May 27 17:59:24 PDT 2015
Bborie,
I'll ticket the problem and as I said earlier, I will fix it myself. You
comfortable with getting the change into 2.2?
Thanks,
Nathaniel Hunter Clay
On Wed, May 27, 2015 at 8:10 PM, Bborie Park <dustymugs at gmail.com> wrote:
> Hm... Sounds like the Makefile needs changing to install librtcore.so.
> On Wed, May 27, 2015 at 4:22 PM, Nathaniel Clay <clay.nathaniel at gmail.com>
> wrote:
>> Bborie,
>> I think it all gets rolled up into rtpostgis.so. As far as I can tell
>> there is no librtcore.so.
>> Thanks,
>> On Wed, May 27, 2015 at 7:13 PM, Bborie Park <dustymugs at gmail.com> wrote:
>>> Nah. The library was meant to be consumed by whomever wants to consume
>>> it. If the header is not copied, that'd be an oversight and a ticket should
>>> be filed... Having said that I need to see where librtcore.so gets
>>> installed...
>>> On Wed, May 27, 2015 at 2:41 PM, Nathaniel Clay <
>>> clay.nathaniel at gmail.com> wrote:
>>>> Bborie,
>>>> The librtcore header is not copied, to /usr/include so I am assuming
>>>> that the library functions included in the library were meant to be
>>>> private. This is for a external project. Is this an over-site? Or am I
>>>> missing something fundamental.
>>>> Thanks as Always,
>>>> On Wed, May 27, 2015 at 5:35 PM, Bborie Park <dustymugs at gmail.com>
>>>> wrote:
>>>>> Actually, yes. raster2pgsql directly consumes librtcore...
>>>>> On Wed, May 27, 2015 at 2:33 PM, Bborie Park <dustymugs at gmail.com>
>>>>> wrote:
>>>>>> Do you mean directly accessing librtcore? I believe you can go
>>>>>> directly at that library if so inclined.
>>>>>> -bborie
>>>>>> On Wed, May 27, 2015 at 2:31 PM, Nathaiel Clay <
>>>>>>> Hi All,
>>>>>>> Could we expose some of the raster C functions to read and write to
>>>>>>> raster’s, and low level pixel to geo-point and geo-point to pixel and etc.
>>>>>>> Just want your input, I am more than willing to do the work myself.
>>>>>>> Thanks,
>>>>>>> _______________________________________________
>>>>>>> postgis-devel mailing list
>>>>>>> postgis-devel at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150527/b1b22fe5/attachment.html>
