[postgis-devel] Winnie is whining
Nicklas Avén nicklas.aven at jordogskog.no
Sat May 30 15:27:21 PDT 2015
Hallo
Regina, I see winnie is unhappy. But I cannot understand how my last
commit could cause that.
  Test: test_lw_dist2d_seg_arc ...passed
  Test: test_lw_dist2d_arc_arc ...passed
  Test: test_lw_arc_length ...passed
  Test: test_lw_dist2d_pt_ptarrayarc ...passed
  Test: test_lw_dist2d_ptarray_ptarrayarc ...passed
  Test: test_lwgeom_tcpa ...Makefile:80: recipe for target `check'
failed
make[2]: *** [check] Error 5
make[2]: Leaving directory
`/projects/postgis/branches/2.2/liblwgeom/cunit'
Makefile:168: recipe for target `check' failed
make[1]: *** [check] Error 2
make[1]: Leaving directory `/projects/postgis/branches/2.2/liblwgeom'
GNUmakefile:14: recipe for target `check' failed
make: *** [check] Error 1
Can it be something else causing it?
Thanks
Nicklas
