[postgis-devel] Winnie is whining
Paragon Corporation lr at pcorp.us
Sat May 30 21:06:19 PDT 2015
Nicklas,
Think I may have found the issue.  At least this change fixed my cunit
crashing.  Rerunning on Winnie to see if it fixes her issue too.
https://trac.osgeo.org/postgis/ticket/3143
Thanks,
Regina
-----Original Message-----
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paragon
Corporation
Sent: Saturday, May 30, 2015 11:36 PM
To: 'PostGIS Development Discussion'
Subject: Re: [postgis-devel] Winnie is whining
Nicklas,
I looked at this some more. On Winnie the error is intermittent on my
machine it consistently crashes in the same spot.
This is just the 32-bit instance.
I don't think it's anything you did necessarily since issue seems to have
been happening since early may on Winnie's 32-bit runs.  I haven't been
paying attention since I've been upgrading things so things are a bit of a
mess on her at moment anyway.
But there does seem to be some instability around that area of cunit tests.
Wonder if anybody has a 32-bit instance to test on to rule out only a wndows
32-bit specific issue.  Whatever it is might be 32-bit specific (or some
weirdness with running 32-bit code on a 64-bit OS).  It wouldn't show on
Debbie since she only tests 64-bit.
Thanks,
Regina
Corporation
Sent: Saturday, May 30, 2015 11:18 PM
I was thinking it might be liblwgeom got stuck somewhere.  I think that has
happened to me before and it causes random problems cause it installs itself
in usr/local/bin or some such annoying place and an old one gets used with
new code.
Seems isolated to the 32-bit version. I think 64-bit is fine.
Anyway I tried to replicate on my dev box running windows 7 64-bit (using
the same mingw64 32-bit gcc 4.8.1) and sadly it crashes on my desktop.
Though location is slightly different.  I get this
liblwgeom code interrupted
passed
  Test: test_lwgeom_locate_along ...passed
  Test: test_lw_dist2d_pt_arc ...passed
  Test: test_lw_dist2d_seg_arc ...passed
  Test: test_lw_dist2d_arc_arc ...passed
  Test: test_lw_arc_length ...passed
  Test: test_lw_dist2d_pt_ptarrayarc ...passed
  Test: test_lw_dist2d_ptarray_ptarrayarc ...passed
  Test: test_lwgeom_tcpa ...passed
  Test: test_lwgeom_is_trajectory ...Geometry is not a LINESTRING Line does
not have M dimension Measure of vertex 1 (1) not bigger than measure of
vertex 0 (1) Measure of vertex 1 (0) not bigger than measure of vertex 0 (1)
Measure of vertex 2 (2) not bigger than measure of vertex 1 (3) passed
Suite: effectivearea
  Test: do_test_lwgeom_effectivearea_lines ...passed
  Test: do_test_lwgeom_effectivearea_polys ...passed
Suite: miscellaneous
  Test: test_misc_force_2d ...Makefile:80: recipe for target `check' failed
make[2]: *** [check] Error 5
make[2]: Leaving directory `/projects/postgis/branches/2.2/liblwgeom/cunit'
Makefile:168: recipe for target `check' failed
make[1]: *** [check] Error 2
make[1]: Leaving directory `/projects/postgis/branches/2.2/liblwgeom'
GNUmakefile:14: recipe for target `check' failed
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Nicklas Avén
Sent: Saturday, May 30, 2015 6:27 PM
To: PostGIS Development Discussion
Subject: [postgis-devel] Winnie is whining
Hallo
Regina, I see winnie is unhappy. But I cannot understand how my last commit
could cause that.
  Test: test_lwgeom_tcpa ...Makefile:80: recipe for target `check'
failed
make: *** [check] Error 1
Can it be something else causing it?
Thanks
Nicklas
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
