[postgis-devel] Winnie is whining
Brian M Hamlin maplabs at light42.com
Sat May 30 23:49:06 PDT 2015
ah right - this is better
 http://paste.debian.net/190185/
On Sun, 31 May 2015 00:42:27 -0400, Paragon Corporation  wrote:
       Brian,
You seem to have a bunch of issues here not related
1)      Looks like you don't have Cunit installed so tests don't
even try to run.
2)      Something wrong with your postgres setup.  So postgresql
tests are failing – better check
/tmp/pgis_reg/regress_log
To see what is up there.
Anyway seems Winnie is still intermittently failing despite my commit
that fixed my issue.  I just purged her local bin to rule out stale
liblwgeom getting in the way and after that it passed, but running the
whole thing again to see if it fails again.
Only difference between my setup and winnies aside from hers runs under
Jenkins (and doing multiple sequential runs)  is I'm on windows 7
64-bit and she's windows 2012 64-bit. Can't see how those would make a
difference and why it's just the 32-bit and intermittent.
The 32bit is at gcc 4.8.1 and the 64-bit is at gcc 4.8.3 so I suppose
it could be a gcc difference.  I think I'll just purge the whole
postgis folder to see if something sticking there.
Thanks,
Regina
From: Brian M Hamlin [mailto:maplabs at light42.com]
Sent: Sunday, May 31, 2015 12:28 AM
To: PostGIS Development Discussion; Paragon Corporation
Subject: Re: [postgis-devel] Winnie is whining
this is a 32bit build just now ..
   http://paste.debian.net/190006/
On Sat, 30 May 2015 23:18:27 -0400, Paragon Corporation  wrote:
       I was thinking it might be liblwgeom got stuck somewhere. I
think that has
happened to me before and it causes random problems cause it installs itself
in usr/local/bin or some such annoying place and an old one gets used with
new code.
Seems isolated to the 32-bit version. I think 64-bit is fine.
Anyway I tried to replicate on my dev box running windows 7 64-bit (using
the same mingw64 32-bit gcc 4.8.1) and sadly it crashes on my desktop.
Though location is slightly different. I get this
liblwgeom code interrupted
passed
Test: test_lwgeom_locate_along ...passed
Test: test_lw_dist2d_pt_arc ...passed
Test: test_lw_dist2d_seg_arc ...passed
Test: test_lw_dist2d_arc_arc ..passed
Test: test_lw_arc_length ...passed
Test: test_lw_dist2d_pt_ptarrayarc ...passed
Test: test_lw_dist2d_ptarray_ptarrayarc ...passed
Test: test_lwgeom_tcpa ..passed
Test: test_lwgeom_is_trajectory ...Geometry is not a LINESTRING
Line does not have M dimension
Measure of vertex 1 (1) not bigger than measure of vertex 0 (1)
Measure of vertex 1 (0) not bigger than measure of vertex 0 (1)
Measure of vertex 2 (2) not bigger than measure of vertex 1 (3)
passed
Suite: effectivearea
Test: do_test_lwgeom_effectivearea_lines ...passed
Test: do_test_lwgeom_effectivearea_polys ...passed
Suite: miscellaneous
Test: test_misc_force_2d ...Makefile:80: recipe for target `check' failed
make[2]: *** [check] Error 5
make[2]: Leaving directory `/projects/postgis/branches/2.2/liblwgeom/cunit'
Makefile:168: recipe for target `check' failed
make[1]: *** [check] Error 2
make[1]: Leaving directory `/projects/postgis/branches/2.2/liblwgeom'
GNUmakefile:14: recipe for target `check' failed
-----Original Message-----
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Nicklas Avén
Sent: Saturday, May 30, 2015 6:27 PM
Subject: [postgis-devel] Winnie is whining
Hallo
Regina, I see winnie is unhappy. But I cannot understand how my last commit
could cause that.
Test: test_lw_dist2d_arc_arc ...passed
Test: test_lwgeom_tcpa ..Makefile:80: recipe for target `check'
failed
make: *** [check] Error 1
Can it be something else causing it?
Thanks
Nicklas
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
Brian M Hamlin
OSGeo California Chapter
blog.light42.com
Brian M Hamlin
blog.light42.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150530/b150b206/attachment.html>
