[postgis-devel] build status on trac
Paragon Corporation lr at pcorp.us
Mon Nov 16 05:58:42 PST 2015
Strk,
Nice charts.
Yes winnie is failing on 2.0.  Configuration error on my part with the json config. I have to take out the hack I put in a while ago for lower json.  I'm not sure anyone actually still uses 2.0 on windows.
Yes trunk builds for Winnie are called 2.3.  I go by the version number since it's used for packaging so I don't want to call it trunk as that has no meaning from a packaging perspective.
The same is done with Debbie -- there is no trunk, just version 2.3 etc.
Also trunk is soooo subversion talk :)
Thanks,
Regina
-----Original Message-----
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
Sent: Monday, November 16, 2015 4:53 AM
To: postgis-devel at lists.osgeo.org
Subject: [postgis-devel] build status on trac
I've added a table with build statuses of all current bots and branches to the trac start page: https://trac.osgeo.org/postgis/
It quickly shows winnie is failing on 2.0, is this confirmed ?
Regina: doing that table I saw that the job naming for winnie are not consistent, and the "trunk" builds are named after "2.3", is that's going to change ?
it would generally be nice to have that table exist as a standalone page to be included in various places, to reduce maintainance costs, does anyone have an idea about how to do that ?
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
postgis-devel mailing list
http://lists.osgeo.org/mailman/listinfo/postgis-devel
