[postgis-devel] gitlab-ci shared builders enabled
Sandro Santilli strk at keybit.net
Wed Nov 18 00:54:04 PST 2015
On Wed, Nov 18, 2015 at 09:28:23AM +0100, Sebastiaan Couwenberg wrote:
> On 16-11-15 13:11, Sandro Santilli wrote:
> > The shared builder seems to be running Debian 8.2 and is
> > configured to use PostgreSQL 9.4. It does not test SFCGAL.
> Would it help if sfcgal was backported to jessie, IOW can the builders
> use the jessie-backports repository?
I think so, if you want to try you could play with it in a merge
request (gitlab) and/or pull request (github)
--strk;
