[postgis-devel] postgis account on hub.docker.com
Sandro Santilli strk at keybit.net
Sat Nov 21 02:10:22 PST 2015
On Thu, Nov 19, 2015 at 02:24:02PM -0500, Paragon Corporation wrote:
> I'd like to be part of the group.
You should be in now.
I hadn't succeeded in producing a docker image which works for usage
in gitlab-ci, if you can, the corresponding Dockerfile could be put
under a ci/docker dir for automatic build by docker (which would fetch
it from the github mirror).
I've been thinking that one we could be using docker images to run
upgrade tests. A system with all official PostGIS versions installed
to allow for running "make installcheck RUNTESTFLAGS='--upgrade-path=x--y'"
--strk;
