[postgis-devel] liblwgeom versioning
Sebastiaan Couwenberg sebastic at xs4all.nl
Fri Oct 9 10:34:16 PDT 2015
On 09-10-15 18:59, Sandro Santilli wrote:
> On Fri, Oct 09, 2015 at 10:36:24AM -0400, Greg Troxel wrote:
>> Sounds good; then I could make a liblwgeom package easily.  But until
>> some other package needs it, I probably won't.
> I believe next spatialite release will be using it.
Building SpatiaLite with liblwgeom support is the recommended
configuration since 4.3.0 as mentioned on the spatialite-users list:
 Anyway packagers and maintainers building libspatialite
 on FLOSS platforms (i.e. Linux and alike) are always
 invited to enable LWGEOM: and consequently the suggested
 standard build configuration on any Linux is now:
 ./configure --enable-lwgeom=yes
,/configure changes in 4.2.0:
https://groups.google.com/d/msg/spatialite-users/S2mY1Tj7BBc/_gWzznEKZnwJ
 the suggested configuration is as follows:
 ./configure --enable-lwgeom=yes --enable-gcp=yes
 this causes an implicit license excalation to GPLv2+ simply because
 both liblwgeom and the code borrowed from Grass Gis (GCP module)
 are released under the GPL.
 if for any possible reason you absolutely need to built an executable
 version of libspatialite fully preserving the initial tri-license (MPL,
 LGP or GPL a you wish better) you simply have to opt for the
 default configuration, i.e.
 ./configure --disable-lwgeom --disable-gcp
 (this will obviously imply loosing some cool useful features).
4.3.0: note for builders and packages:
https://groups.google.com/d/msg/spatialite-users/uawzaLjzbo4/_0JqJ8a6HmAJ
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
