[postgis-devel] 2.2.0 passes regression tests on NetBSD 6 i386, perl path issue
Greg Troxel gdt at ir.bbn.com
Fri Oct 9 12:53:36 PDT 2015
So I will further suggest, without having tested
For all Makefile.in files:
  replace all instances of $(PERL) with @PERL@
  drop "PERL=@PERL@"
It also seems awkward to be setting any variable locally that is set by pgxs.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20151009/efce0526/attachment.sig>
